Battery charge problem
Jakir90
Hello, I am using Xperia z1. I got lolipop update around 2 month ago and update. It was working fine. Last month I got another system update and updated to 14.5.A.0.270
After update my battery charger going down very quickly. What should I do. Please help me.
6 REPLIES 6
Jakir90
Thank you very much for you help. I checked it, also repaired my phone via PC Companion. But no luck Slightly_frowning_Face
I am having this problem after updating to 14.5.A.0.270
Samuel1
Hero
Could you please post a screenshot of your battery graph so we can see which apps that use most battery?
Jakir90
Thank you for replay. Here you can check.
Samuel1
Hero
That graph looks a bit steep indeed. Did you reset the phone after you repaired the software? If not, you can give it a try. The other thing you can do is to send in the phone to a service center. See my signature for contact information to your local Xperia support.
Jakir90
Thank you. I did it. Is there any problem in 14.5.A.0.270 version?
