Bad sound quality after 5 - 10 minutes
SteGen
Hello,
Does anyone has the same problem with the sound, that after playing about 10 minutes the sound quality goes bad and you get a lot of noise and cracks..? This problem is the same using Xloud or not. I did also test that after playing music 10 minutes and the quality goes bad, selecting Xloud the sound is again good but the same after then minutes again bad sound quality...
Do I need to let my phone repair??
Thanks already for feedback on this issue.
Best regards,
Steven.
2 REPLIES 2
Sam
Legend
Legend
It is very strange that it is happening after a defined period of time. This does lead to believe that it is not hardware related or it would be more consistent so it may be worth running an update/repair:
and install it on your PC.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
SteGen
Thank you for the fast reply!
That was my thought too, strange that it only happens after some defined period, but regrettably trough.
Yesterday evening followed the instructions you've send but this is not the solution.
I've asked my vendor what to do and they will have a look at it.
I've also tried playing FLAC what is normally the best quality but the same result after a while bad noise comes trough...
I will send my phone tomorrow to my vendor and I'll send you an update when I get my phone back.
Again thanks for the respons.
Steven.
