Back Light - Adjustment Problem in Xperia SP
rvsiva17
I’m unable to Switch back to my previous Light Setting.
Assume that I’m using 70% of Brightness in Back Light Turned “ON”
Then if I turn OFF the backlight, Then Brightness goes to 0%. That’s fine. Slightly_smiling_Face
Again When I Turn ON the Backlight, The Brightness Level Goes to 100%. Slightly_frowning_Face
How can I get it to 70% again as default, rather adjusting the brightness manually every time..????
Regards,
Siva Kumar.
12 REPLIES 12
do you have an app or how are you changing this brightness settings? (widget, apps, settings menu)?
rvsiva17
I'll switch my Backlight ON/OFF in Status Switch Widget only.
But Brightness I'll go to Settings>Display>Brightness Menu Slightly_frowning_Face for Everytime.
regards,
Siva.
do you have auto adjust brightness selected?
rvsiva17
No, If i do Adapt to Lightning Conditions - I Fell the Screen is Flickering :smileysad:. So I've not given it.
Regards,
Siva.
nuttyspark
Explorer
Hi. I found the same as you with the 100% brightness using the widget. I feel that I have a different problem. When I select "Adapt to lighting conditions" the screen just seems to go a little darker but it doesn't change when I cover the light sensor.
Does anybody know how I can check if the light sensor is working?
Crowley
I have exactly the same problem... it is most annoying especially in bright conditions where you can't see the display properly to manually adjust the brightness settings.... Sony sort this out!
dm84
*#*#7378423#*#* then go to service test
gre
in screen test in grey color i can clearly see the backlight flickering... whats this man? all this after 4.3 update. software issue i think.
saurabh88
Too much Flicking backlight damaging my eyes **bleep**
