I recently updated my Xperia Neo to ICS 4.0.4.
Now, every time i plug in a USB-cable to charge the phone, it also connects the SD-Card with my PC.
In 2.3.4 there has been a setting to disable this behaviour.
Is it possible to do this in ICS? I can't find such a setting.
are you using MTP or MSC mode ???
I'm using MSC mode
ICS will auto-mount your SD card if you use MSC mode. There's no setting you can change for this.
If you just want to charge your phone via USB I suggest that you use MTP mode instead.
Ok, thanks for the info. I will try, but i liked the choice from 2.3.4 better 😕
