Audio settings
Nouza
Audio settings
I've accidentally disabled audio settings in my phone...after a restart it was not there...nd the audio settings in the music player tells ' Unfortunately, Musicfx has stopped '. Nd clear audio + nd equaliser disappeared from there nd audio settings in Sound & Notification settings also disappeared!! Pls hlp...
Tags (1)
11 REPLIES 11
@Nouza
Have you unlocked the bootloader?
settings > apps > all > scroll to the bottom, perhaps you disable it
Bandolero
@Nouza wrote:
@Bandolero thts what the problem is!!! Thrs no audio settings in the Apps->All tab!!
Since you're using a Z3+ and for sure is on android 5.0 and above. You should see something like this as per screenshot, lets wait for approval so you can view it. The disabled app will show on another page which is located on the last page right after the "All" tap.
But if you done have that, then please let us know as what @uliwooly have mention. Did you root the device or flash it with a different custom rom or somewhat.
Something that i miss out, if the app or the items that shows under "All" is been disbaled. It will definitely not show up anymore on the "All" tap, on older android version. It use to show on the very bottom of the "All" tap. But with the newer android version it is being seperate to a different page to avoid confusion.
Regards,
