Audio Jack 3.5 mm Problem
Z3CMH
I have several audio systems that I want to connect to my z3 compact via the 3.5mm audio jack, but the majority of the cables I have do not connect it. The sound just remains going through the Z3's speakers, or in one instance it assumed it was a microphone . These all worked with my old HTC phone. Does the Sony require a longer plug, if so where can I buy one? Or is it faulty? Is anyone else having similar issues?
9 REPLIES 9
That's odd, have you try the basic, restart the phone, if its a regular headphone or 3.5mm cable should work, unless the headphones have any type of control, then you will need a 3.5mm 5 pole audio contact
http://www.xperiablog.net/2014/03/09/sony-mdr-nc31em-digital-noise-cancelling-headset-now-in-stock/
Z3CMH
Restarting has no effect. Some standard jacks register as headphones, some do not. Even one of the leads I have disconnects mid use. A four pole cable does not work, whereas a  A pair of Beats with a mic with an inline control and 4 poles does (although controlling spotify requires the app to present in the lock  screen which it isn't always! All very annoying, no in car use, can't connect to hifi etc.
Can one purchase a 5 pole connector to two phonos or another 3.5mm jack, although not sure this will help? I think it may be  the Smart Connect App cocking it up. I am considering force stopping this to see if that helps.
Anyone else have similar issues?
gtop
Yeah, 5 poles are only needed for the noise cancelling headphones, AFAIK; all my 4 pole headsets with inline controls that are made for Android work just fine; I can't find any 3 poles that don't work or aren't recognised as headphones (even Apple's standard buds are OK), but that's not saying anything unless we're both testing the same cables Slightly_smiling_Face
I'd try resetting the Smart Connect data via Apps > Smart Connect > Clear data, and if that doesn't work maybe take to Sony to have a look at.
Z3CMH
Thanks for replying.. Have tried clearing Smart Connect data but to no effect. The problem appears to occur with connecting cables (to connect to the car or a hifi) it so far hasn't occured with headphones. I have even had the phone assume I was connecting a microphone.I have seen another post regarding a Z or Z1 which said that connecting a splitter and plugging in headphones on one side and using the other to output  works, but that is hardly an elegant solution.
I  have downloaded Sound About app which has a widget which so far  does work but I need to experiment more with it as the  this morning it  silenced BBC iplayer when I docked the phone.
It seems rather poor to have to rely on a third party app to solve something so basic. I think that Smart Connect is much more trouble than it's worth, at least for how I want to use the phone, either it should be updated so that it senses connecting cables as headphones or why not at least add the option of turning it off and having a manual override widget. Sony?
You might want to contact Sony directly
36210720
New
Hi guys... I bought my Xperia 2 weeks ago and I got a problem since wednesday. When I put the headphones into the jack, only the left channel is working.. and there's no sound in right... What to do? (I've read for Smart Connect, but it's not working) Thank you
bacobaco
hi, could you fix it? i have the same problem with my z3 compact.
jur3
I have the same problem with my z3c.
The problem isn't from various cables, problem is with your 3,5mm in your phone.
One day a friend of mine, who also has z3c, came to my place, and the cable that didn't work with my phone worked with his phone. And that got me thinking Slightly_smiling_Face
And the funny thing is, the cable was Sony certified x) The irony.
So use your waranty and fix this.
dakuhonoo
Just get an OMTP to CTIA adapter, Sony unfortunatelly firstly supported OMTP then jumped ship to be compatible with apple and older jacks don't work with new Sony devices, it's annoying .
