Hi Sony,
My Sony xperia lt28 at audio works for the notificacions although not for the media. If i use the radio as Speaker with the earplug Works.
Please advise, is an Att cellphone but right now i am overseas and is outside of a contract. Already Flash it erasing all the data and it did not work.
Hope to hear from you soon.
Regards,
Nady Villar.
If the speaker is not working even after a software repair or Factory Reset, then I can only suggest that the device be looked at by a Service centre.
I suggest you use the below link to contact Sony Mobile Support within your region.
Hi Jake,
Thank you for your prompt response.
I just found a work around, please see the steps below:
1- Opened the fm radio.
2- Set the Speaker option. ( while i was doing that previously the Speaker would work but nothing else).
3- play the fm radio in the background.
4- Open another application that uses media sound. ( Walkman application does not work, please use any other application as youtube or play a video from Facebook).
5- Unplug the earphones.
6- Bang! There you have your sound back and stereo.
Thanks responding.
Hi Jake,
Now it does not recognize the earphones when i plug it in. any ideas?
