For the past 4 days, All the Applications i am running is getting terminated without any information. I am not sure what is causing the error. But When i play, when i text a msg in whatsapp, when i check the photos in Album, the applications are terminating and the phone goes to the home page.
I have uninstalled few games and few apps to increase the RAM Speed. But in vain.
Kindly let me know what is causing the problem and the solution.
Thanks in Advance.
Actually this is the way the Android system is intended to work. To close the oldest running app when a new one is triggered (if RAM is needed).
So if you would like to avoid this you'll need to check which app's you have running in the background from time to time and close the ones you don't use.
did you try to restart your phone and see if problem persist?
Hi.
Yes. I have tried it a couple of times. i have even uninstalled few apps also. the problem is still there.
app like whatsapp also terminating in the middle of texting.
