hi all,
i have this weird feeling there is something wrong with my antenna on this device, when i hold the device and look on the antenna it goes away, it looks like this iphone problem, so if i hold my grib on the lower right part my antenaa is not available anymore, so far i had many problems with calling to and being called by other people, as I still running android 2.3 will this be fixed in android 4 ?
i have this device since oktober this year, but lost fast confidence as signal is too low, too many times.
I have not been able to replicate this problem myself. However as you have stated that this happens when you hold it in a certain way this does imply that you may have a hardware issue in which case I would advise returning it for assessment by an authorised repair agent.
