Another dead Z1 compact
chaikc
hi guys,
really need some help here. I have a 2 week old Z1 compact where the batts totally ran out. I got home, plugged it in, and waited for an hour before realizing that i still can't switch it on.
So far I've tried the following.
1, when i plug it in, it shows a solid red light.
2. If I do a power + vol. up button reset or red button reset, the notificaition light will blink for about 10 seconds, and then go back to a solid red light.
3. if the on/off button is pressed when disconnected from the USB charging cable, it will flash red 3 times.
4. Phone has been reset, and left on to charge for the last 8 hours, but still nothing.
It is driving me crazy. would appreciate any help here.
Thanks!
2 REPLIES 2
alexrx
Enthusiast
Hi there,
Try the following:
Connect your phone to a wall charger > Press and hold "Power Button" and "Volume Up" at the same time for 10 seconds(3 vibrates) - or press and hold OFF Button  for 10 seconds > Let it charge for 2 hrs > Repair/re-install with Sony Update Service.
Sony Update Service
Cheers.
profile.country.RO.title
_alexdon_
@alexrx wrote:
Hi there,
Try the following:
Sony Update Service
Cheers.
Try the suggestion above,if it does not work,visit a sony service:
alexdon
