Have you enabled talk back?Settings-accesibility-talk back,disable.
Hi Franni and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
The good news is that the "Read Error" message problem is very easy to fix: Main Menu > Settings > More > Untick NFC. Alternatively you can remove the NFC enabled card (Bus pass, Credit card etc) that is in close proximity to the handset as this is the cause of the error.
Thank you!!! Problem solved! I didn't know it was a NFC problem. Thanks again!
ty for the help i had the same error, NFC error (maby couse my 2 sony xperia z was near each other idk) :smileysmileythumbsup:
I have the same problem, and i have setting already "TalkBack = Disabled" !!!
It' s very annoying !!
Have you a different solution ?
Thank in advance,
I have finded the solution , following sony indications : Untick NFC .
Thanks, Mizar110
