Android OS battery Drain
arj154
Hi
I've been using my phone as I would do normally and I've found that my phone stays awake for the majority of the time the phone is on. It never seems to truly enter deep sleep and during the day i am on mobile data and I have wifi off. Today I have been listening to podcasts for about 1:30 hrs and at that point, The screen on time was 1:15 hrs. I really cant work out why the phone is draining in battery and being awoken so much. I've had messenger installed on my nexus 4 and it didnt drain my battery as much. I've tried switching to 3G only, only allowing wifi on during sleep if its charging, uninstalling facebook, switching off image enhancement, switching off and smart backlight control. I really cannot work out whats causing the issue.
Android OS
Battery
wakelock detector
Kernel Wakelocks
CPU Spy
stats
3 REPLIES 3
razvan
Hello,
I also have the same problem as per attached screens
Till now i never had Andrpoid OS system in top of apps which are draining battery. Only Screen i had in the top which was OK
I don't know what happened now
I have my Z3c from 17th of October
SungoEsdown
I have the exactly same problem. OS Android drains battery. About 40% usage. No apps from third parties, no hacking or something. Please help.
JPN
Time to time the Google makes tricks. The beginging of the month the battery consumpition sky rocketed. After receiving the Android system Webview -update the situation has been normalized.
These really are nasty problems 'cause you cannot fallback, remove nor disable those ones. 😞
