Hi to all!
I want to create apps for android, but I can not find adb driver for my phone (Sony Xperia E Dual)
My PC see my phone as Pocket Device, but not as Android device, so I can not working automatically with it.
Please, tell me where I can get adb driver for Xperia E Dual
I can see that there are no drivers uploaded at Developer World yet so I suggest that you download the Android SDK and use those drivers.
Actually at this time I have android SDK on my computer and another smartphone (gygabyte gsmart g 1345 ) detected correctly as android device, but Xperia E Dual my PC see just like "Pocket Device"
So what I need to do?
Bring my smartphone back to the shop?
Are you sure that USB debugging is enabled in the phone?
Go to Settings and Development settings and check.
*pokerface* I am using ukrainian localization.
There was not any item, that was seems to developers mode.- So in previous days I simply did not found it.
When I put my smartphone to english version - I found it!
Now ok. Developer's mode (Debug mode) is active.
But main problem is still present. There is no driver for Android adb Interface
So windows can not use this device
My variants:
1) I tried to use driver from android-sdk/extra/usb/
2) I tried to use driver from folder, where placed Sony PC Companion 2.1
3) I tried to use driver from XPeria SX (it is for ICS too)
All of this variants was unsuccessfull.
If you downloaded the USB-driver in the SDK i believe that driver should work but you may need to force the installation. Go to the device manager and select update driver for the device. Then manually select the driver to install instead of automatic install and uncheck the "show compatible hardware".
Same issue with my Xperia Z (C6603)
Can't find drivers.
USB debugging is enabled.
I tried all provided on Developer World for Xperia Z drivers (not C6603, the is no driver for c6603)
allso tried android universal driver. System just doen't accept them.
