I tested this solution.
It wotks but need some attentions.
1st after this commands you will need go to memory settings and make a move to sd card from internal memory
2nd some apps cant works properly with sd card detected and not mounted as external sd card. This fixed by using mixed mode instead private. As example "sm partiton disk:179,6 mixed 10" give 90% of sd cards size to internal memory and 10% to public.
3d some apps and os dont fully support this mode so much data will stay in internal memory and will be saved there while installing such apps and works with them.
So the better way is either use accesseble with stock settings transfer to sd card apps that support this and using sd card sandbox for apps data/cache or waiting for Sony or/and Google to make solution fully worked with all apps.
