allow updates when using my phone as modem
Hi! I have xperia mini and i'm trying to update. The problem is, i only have wifi to go online. I found this option 'allow updates when using my phone as modem' in PC COMPANION, checked it but it still wont work. What is the problem?
4 REPLIES 4
profile.country.PH.title
MarlonUk1
afaik, the option meant if you allow the PC companioon to update the program itself if you use the phone as modem.
thank you. i visited a friend and did the update there.
btw, just now I figured out that you can use both SD card and phone as modem only with the companion installed, which without it wasnt possible.
you can't use your phone as a modem to update the same phone
http://talk.sonymobile.com/thread/44888
MarlonUk1
actually there are otherways your phone can be used as modem or share internet to your pc/laptop.
there is of course the USB teethering, hotspot, or you can create manually a dial up connection via the network settings in windows ( though its called "dial up" the speed would depend on your networks data speed) Slightly_smiling_Face
