ALbum folder suddenly brought back all the deleted pictures previously one day .There were thousands of pics and i finally restored factory settings and gave the mobile for service.
It worked fine for 1 month , again now i have an issue with an applications stickers being seen in albums. there are a 100 stickers and i don't know what to do . I'm not sure whether or not to give my phone for a service again.
Phone is dead slower nowadays.
It automatically shut downs if it gets hanged .
Help me out .
Try performing a system repair as this will often fix issue after an upgrade - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you see pictures that belongs to different apps in Album this can also be cuased by that app not putting a ".nomedia" file in its folder. See this thread for more information: http://talk.sonymobile.com/t5/Xperia-L/Hide-folders-from-Album/m-p/518865
