Alarm ringtone
Alarm ringtone
Firstly, I can set the alarm ringtone as I like but now can't. I forgot the method. I put the many ringtones to my SD card but it's only in the ringtones. I can't find the Alarm Ringtones whcih have a SE default ringtones. So, how can I set the songs?:smileyconfused:
5 REPLIES 5
sushidushi
You mean you want to know how to use a song as your alarm tone?  Using the standard alarm, open the alarm you want to change the ringtone for, and then select ringtone.  On mine, I have the choice of using 'Android System' or 'Select Music', but judging from the icon for Select Music, it's because I have an application called handcent on my phone, which you might not be able to get, if you don;t have access to the Market.
If you do not have the option to 'Select Music', you can still do it.  Before you open the Alarm Clock app, select the song you want to use, press the menu key (bottom left) and press 'Set as ringtone'.  Now go to Alarm Clock, open the alarm, press ringtone and then Android System (or whatever yours says).  The song you selected should now be in the list of alarms you can set, together with the pre-set alarm tones.
I hope this makes sense and helps...
You must first place the music into the Ringtone... Then just tap into the alarm and select Ringtone....
I just found this out: But if you swipe the clock at the Alarm setup page, you can change it to several other clock displayed as your alarm.
Yeah man! Firstly, I do this way to set the alarm ringtone but now I can't see the ringtone. It has only the default ringtones. You are very convenient coz can use the android market. I'm unlucky and our country doesn't support it. I think coz it is only still in " Loading" but it can open the help center in browser. So, I test in computer that can open the home page and the other link pages aren't open. So bad country!!!!!!!!!!!!!!!!
Er_Kannan
Connect the phone to PC and create a folder named ringtone if it is not present in the SD card. Now copy all ringtones to this folder and you will be able to set the ringtones for your alarm.
yeah! I already make this way but it's only visible in ringtone that is in the sound & display.
