Hi guys
for alarm :
you can try to clear cache and data , by doing
settings -> apps ->all -> clock -> clear cache/data ,then you can restart phone do disable the clock and enable back, you can find this option where you found clear cache
about battery :
after updating it takes time , same happened to my phone when i did updated the software (which is not 4.3)
what I did
i read in some post saying, charge the battery for entire night(only once)!!! after updating, i felt what it does, but believe it did some trick, so before i going to bed, i kept my phone to charge for entire night, then morning restarted phone, from then i dont had any issues about battery, i am not sure it might work for you people, but worth a shot
let us know
Manjuboyz
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks
Thanks for the advices, Manjuboyz. I have followed your instructions but the clock stills work weird (again without the options of adding/deleting alarms sometimes) and, the battery drains so fast that I needed to charge the phone the second time within one day even while the Stamina was switched on and during Sleep (Standby) Mode.
Hi Yun6
>thanks for trying , what i can suggest is , if you have all data backup try to do Restoring the phone(you will be losing all data), any software glitch will be resolved doing so, try this it worth a shot
Manjuboyz
NOTE:
Hi Yun6
>this is what we can do to help till restoring the phone, if you have any Sony Center available nearby, i suggest you drop by so that they may suggest you or fix the problem which your phone is facing
Manjuboyz
NOTE:
When you tap to add new alarm and have adjusted the settings to what you want then in the top left corner you may have a tick which you need to tap to save the alarm and it's settings
