I'm using some agenda in Gmail (near 10 or 15), in the standart application(google app) i have the agenda name when i select an event, but in the sony application i don't find where i can show the name. Do you know if there are some option or evolution.
Did you meant to say the Calendar app? if so you should have 2 Calendar apps, one from Sony and one from Google, open the Sony Calendar app > menu > calendars > select your gmail account also
settings > accounts > google > make sure that you are syncing your calendar and that sync its on, otherwise it won't work
hi,
for my both app, my google account is sync, and it work perfectly.
with my sony Z1 i have by default the sony's calendar but i don't see the calendar's name so i try with the google's calendar. Do you know if there is a forum this app.
