after i updated my xperia sp...to 4.3 android...there is a constant message that says...the process..
android.process.media has stopped working...
please help...it is creating a lot of problems...
Retry the process with sony update service.
what do you mean by retry the process with update service??
Download sony update service,repair your phone(reinstall latest firmware).
No no no just wait. Back in days I had same problem with my LG P350 after I updated this. You have reset to factory settings your phone and everything will be okay. Or do Hard reset.
it worked after reinstallation...thanks
Anytime.Do not forget to select the correct answer for other users to see.
Same problem here.. I downloaded the Sony Update Service, but I don't see Xperia SP in the Products list. Any ideas? Thanks
Are you using Windows 8 or 8.1?? Cause Windows 8 and 8.1 doesn't show Xperia SP in Update Service and also doesn't allow to Update Through PC Companion. You must run Update Service In Compatibility Mode or Use a PC which has Windows 7.
Run SUS in compatibility mode with windows 7.
