Activity phone not responding - problem with calling
Urbancrash
I bought my Sony Xperia P a few months ago and I have been experiencing trouble with calling and receiving calls. When it rings, I can't answer the call, it freezes and stops responding. Or I answer and it continues ringing while I talk to the other person. Similarly, when I try calling somebody it stops responding; sometimes the other person can hear me, but my phone takes around 20 seconds to respond. I usually have to restart the phone in order to use it again.
Hope anybody can help Slightly_smiling_Face
11 REPLIES 11
gwhispererz
Hi, try repairing phone software with PC Companion or Update Service.
Be aware that this process will erase phone data completely, backup if necessary.
Don't forget to mark correct answer as Accepted Solution.
If you find the post helpful, press Kudos.
Urbancrash
Hey,
I tried that a month ago ago, it helped for a few days and then the problem returned
gwhispererz
Maybe try booting phone in safe mode to check if any app is causing the problem.
Urbancrash
Ok, I am going to try that and see what happens.
If another app is causing the problem, how can I know which one?
Thanks for your help Slightly_smiling_Face
gwhispererz
If that is the case, you need to eliminate them one by one, unless you suspect one.
Good luck! Slightly_smiling_Face
Urbancrash
Okay, that will take some time Slightly_smiling_Face
But thanks a lot for your help, I hope I'll solve it!
gwhispererz
You are welcome. Slightly_smiling_Face
248114
Hi, do u have any idea, which 3rd party app causing this problem? In safe mode my phone is working normally. Thanks in advance, sreejesh
Urbancrash
Hey
I still don't know what caused the problem, but I managed to control it by switching my phone off every other day. It is turned on all the time and as soon as I notice problems, I just restart it and it works for a few days. Not really a solution, but you can try it 🙂
