Hi I cannot get HDMI from my Acro S phone working on my tv, I have tried on my friends xperia arc works fine,
The tv launcher app and hdmi says its ready , but it keeps vibrating and flashing on and off, when I tap tv launcher it just turns off , does nothing and turns on again.
anyone any ideas?
i have cleared data smart connect , updated google play , anything else i can do ?
I´ve tried to different HDMI cables and I can´t make any of them work on my PC. I can´t find any support by Sony or elsewhere.
1) Have you tried disabling the TV Launcher?
Go to Settings > All Apps > TV Launcher > Disable
After that, when plugging to TV, the phone should mirror whatever you are doing...
If that does not work:
2) Go to the Service Test by dialing *#*#7378423#*#*
Service Tests > scroll down to "TV-Out Test" > TV-Out Settings
And tell us what settings do you have.
Resolution/freq: (Should be whatever is compatible with your TV... for example, mine works with 720p@60Hz, 1080p@24Hz)
2D/3D Support: (Should be 2D)
