Hi everyone,..
Have updated my phone to xperia acro s 6.2.B.1.96
and now i have a problem ,..
when trying to add a phone number to a pre excisting contact , it doesn't show me my pre excisting contacts and i should enter the contact and choose edit to add the number i want to add ,...
also can not export contacts to internal storage , when trying it says " there is no contacts " despite i have all my contacts saved and make/receive calls perfectly !!!
Crazy ,... hah !!!?
Also i repaired my software many times through pc campanion and update service ,... any help ??
How about if you sync all your contacts to Google ?
After you ran the software repair, what method did you use to get the contacts back into the phone?
the backup application that comes with sony firmware is good except when use to restore contact, it doesn't restore me all my contacts
So i uses "GO backup & restore"
it should restore all your contacts, unless you kept some contacts on your SIM card (not your phone)
