Abrupts my call
Jazc
Abrupts my call
My Xperia go turns off my calls, when Im talking. Doesnt help to hit startbutton for dark screen.
6 REPLIES 6
profile.country.RO.title
_alexdon_
Is something covering the proximity sensor?
alexdon
Alexander1
Make sure that you have the latest available software, you can update your phone using PC Companion:
I would also suggest that you try to boot your phone into safe mode to see if the problem may be related to any 3rd party app that you have installed in your phone:
If you experience the same behavior in safe mode, I suggest that you try with another SIM card.
clucianic
Hi Alexander, I have almost the same issue but when I try to call certain numbers. Certain calls (numbers) won't go through (even though sometimes do) and my NEW Xperia Go inmediately locks its screen after the first tone. How can this be solved? Thanks!
Alexander1
Make sure that you have the latest update for your device:
Also test the proximity sensor using Xperia diagnostics:
https://play.google.com/store/apps/details?id=com.sonymobile.androidapp.functiontester&hl=sv
Tias79
hi
i have the same problems my call`s both incomin and outgoing are disconected. the phone goes back to the startscreen after. I have testes diagnostic program with out any luck. i tested turn off 3G and it works better almost perfekt but then i get problems whit my app´s and mail.
Alexander1
It sounds like there may be some network error. If you have checked that you have the latest available software, I suggest that you try with another or a new SIM card in your phone to see if you still experience the same behavior on the 3G network.
