a difficulty i face with my xperia device that aaps are automaticly crashed after a software update through my pc
Try performing a system repair as this will often fix issues after an upgrade - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
