My device does not read the sd card, but after reading format. After a while, stop reading again, though in the "memory" shows that the sd card is connected, how to solve this problem?
Reformat the SD card
formatted like a lot of music to copy the folder, the error is again a problem. Do not open this papku.no stick reads. And off the Walkman player, third-party players are working fine. If you delete the music, the Walkman player turns normal.
tried povtoryaetsya.Utochnyu problem that I try to copy music, that's when it all into one folder to copy the phone does not want to run this folder, but if the parts in different folders, folder, and then starts the music.
