6.1.A.2.45 Battery drain Problem
GUL
Please any one can help me. because sony will not solve these basic problems.
2 REPLIES 2
Johan
The awake process is something that is being looked at as we speak.
How long have you been running on .45 firmware?
sbkhbk
Hi GUL,
1. Charge your battery fully. (From Graph i see that your didn't charge your battery even once, thatsy the graph is continued for 8days and lots of Up & Downs)
2. If you set "3g/GSM" as your network; please select either 3g or GSM. There is a bug on sony firmware (for using both network)
3. Make sure you use Wifi/internet network regularly, that will reduce "Android System" usage.
