Good afternoon,
My terminal notifies me I have a new system update is available, the 6.0.B.3.184, I try to update it using the PC Companion and I can not do it. I stay in step 2 of preparation. When it seems to be prepared to update the terminal is turned off and does not update the system. I follow the steps given by PC Companion but I have not updated. Can you help?
Thank you!
up to step 2 it will download the updated software to system .....then u have to disconnect from usb and switch off the phone and after 5 sec press the vol down key and connect to usb then the hardware is recognised and update will continue.......enjoy
When I'm in step 2, setting the phone, the phone goes off. Is this normal?
That's when I disconnect usb, I reconnect by pressing the volume key .... I still can not update! :smileyangry::smileycry:
Thanks
