I do not own this post or whatever, just sharing.
Guys, can anyone try this rooting method and report back? I was not
able to bring my USB cable at work so I am not able to try it now.
STEPS
SOURCE
[P/Go][ROOT] DooMLoRD Easy Rooting Toolkit (v14) {perf_event exploit}[20130624]
XDA Thread Link http://forum.xda-developers.com/showthread.php?t=2335992
Thanks to DooMLoRD from for the method
Thanks to eswawan for sharing it first in the Xperia Go Android Development XDA page.
Hope this helps and hope it works. :smileygrin: :smileygrin:
MODIFICATIONS AFTER ROOTING
I added this because I want to share what I and you have done with the Doomed XGo
phone after rooting. Please let me know what you have done too so that we can add
them to the list below. THanks
1. Modified the Phonebook, Phone and the Messaging app with DARK Themes
click here originally by jatinrungta from XDA
2. Debloated [JB Update] [6.2.A.1.100] List Of Apps/Bloatwares That Are Safe to Delete. Thanks to taboo5200 for the safe list :smileygrin:
3. Installed Root version of greenify to save battery and RAM. Check here
I will add more if you tell me so. :smileygrin: :smileygrin: Thanks
How to unroot it back?
Hi, sissy...
i finished rooting and all...but when i try to darkify i cant able to copy the the downloaded apks to systeem>app...
i dont have permission.. its read only, i think so..
help me in this..waiting for ur reply
Hi Davidmarshall,
You need some root explorer [ES Explorer, etc.] or the likes. Enable Root access then
Mount R/W to system and of data..
im gonna root my go but the only reason that i wanna root it is to fix the lag of the calls log and making calls etc ,afer i have updated it to last dam android version 4.1.2
So is that rooting gonna fix that problem ??? does any one had the same problem and it get fixed after this root ??
thank you ))
Hi bro SonyG0,
I haven't really encountered much of Phone Call lags since I bought this phone.
Very minimal with occasinal restart/reboot (twice to thrice a week).
The rooting per se does not help improve the performance but if you do remove
bloatwares that you do not use yourself, then you will be able to save RAM and disk
space. What rooting does is it gives you full access to your system and/or data directories
to be able to have full control over what apps you want to install. But not all apps can be
safely deleted. The list is in the link below.
Hope this helps.
Thanks,
Eljun
Hi Jdvaghela,
I do not exactly understand what you are talking about and why does it not work for you
but you may elaborate if you like to get some help. Thanks
Nothing happens after this.. what can I do?
stupid question, but I'm going to need to used the xperia phone companion software to back u my broken phone and then sync my new phone to my old phones content.
I'm guessing I should do the sync first, then update to ICS/JB (which is better? can I still update to ICS after the JB update release in april?) and then after all of that, root the phone and start theming, correct?
also, smart keyboard-pro and handscent should work fine with a rooted ICS/JB XGO right?
I think that is the part when you will have to wait patiently. how's you phone? Rooted or not?
Make sure that all 5 required steps above were met.
