Dear Sony support team,
I am writing to report the walkman app problem after upgraded to 9.1.A.0.490.
I plugged in a earphone(Sony XBA-C10) to the xperia v, then play the mp3 files stored in SD Card using the walkman app as usual. I pressed the power button to switch off the screen, the music continues, but when one track ends, the next track could not be played unless I press the power button to switch on the screen.
I've already used PCC to repair the phone, and formatted the sd card, reinsert all the mp3 files to the sd card already. I've also tried to store the mp3 files in the internal storage, but the problem still exist.
I have used sony, sony ericsson mobiles for a long time, started from k610i, T700, Aspen, neo, p, v uptill now. It's hard for me to recommend others to use sony mobile unless the problem is fixed.
The problem is exactly the same as the walkman issue of xperia T, TX.
http://talk.sonymobile.com/message/407202
Best Regards,
Hi
My Experia T has been doing the same. I have tried a different medai player and it does the same so I can only assume its the phone not the Walkman.
I called Sony today who told me to repair but as you say it makes no difference. The problem affectively renders the phone useless as a media player unless you hold it in your hand the whole time.
Sony, please fix this problem.
Cheers
I have already escalated this issue but thanks for sharing your feedback.
