My xperia T only connects to 2G network and I can only navigate in edge, previously my xperia works in 3g and hspa normally. I´ve checked the APN and Network Mode configurations and everything is fine, please I need help
Hi jeeda2107,
With the information supplied, this could be related to a few things. I first suggest trying another SIM card to see if the issue is related to the SIM.
If the issue continues, I suggest contacting the network carrier, as they may be performing maintenance on one of there towers close to you.
Please try these first and let us know how you get on.
I was trying but it doesn´t work, the problem with my phone is all the time and everywhere and call quality is really bad. I hope you can help me because the phone worked well and without reason began to fail
