3G doesn't reconnect properly
savcom
Hi.
My Xperia S has been suffering from poor 3G connectivity since I had my firmware changed by PC Companion to 6.1.A.2.45.  I was on 6.1.A.2.50.
Now, once or twice a day, I have to turn the phone off and on again to restore 3G connectivity.  The background is that whenever I lose 3G connectivity (entering a tunnel, for example) the phone signal comes back, and I can use the phone, but, despite showing a G or an H on the phone signal icon, no data transfer takes place.  Switching to aeroplane mode does not restore connectivity - I have to power off/power on.  This never happened before and quite frankly is starting to really irritate me.
Can Sony please confirm for me if
  • this is an acknowledged bug
  • why my firmware was updated 'downwards' (I'm in the UK)
  • does 6.1.A.2.55 fix this
  • when 6.1.A.2.55 will be available in the UK?  (and if not, why not?)
Thanks in advance
5 REPLIES 5
savcom
Quick update:  As I switched back from this screen to PC Companion, I see that I am being offered 6.1.A.2.55.  I am upgrading now, so will report back if the 3G connectivity issue I am experiencing has been addressed in this version of the firmware.
Thanks.
JYraya
Man! where are you from? I'm with the same problem! If this update really works please, post it again to me. I'm geting mad with this same situation!
Thanks Slightly_smiling_Face
ymagriso
+1
I am also facing the same issue.
skip0pot2mus
happens to me too, though simply turning off data and turning it back on resolves it...
JYraya
On my SL, I try to power on/off, but it doesn't work. I have to power off/on to back to work... And My version is the last ;/ No luck again with SONY celphones ;/
