2G
PeymanLasemi
2G
Is Xperia Z2 support 2G Sim cards?
20 REPLIES 20
PeymanLasemi
I trimmed sim.but this sim working correctly in Z1
Im sure the Apn settings are correct
now that's quite odd, what if you re-enter the APN settings manually?
PeymanLasemi
Im do that!
I Contact with the operator and they send the settings for me but the same result
which carrier/network do you have? and which version of the Z2 do you have?
PeymanLasemi
Mobile network(gsm)2G
D6503 with the latest update.314
Rickard
Should not cause this issue but if your SIM only supports GSM, make sure you have selected GSM only under Settings -> More -> Mobile networks -> Network mode.
Could you try a real microSIM as well?
PeymanLasemi
Its set to GSM
I cant acces the real micro sim card.i tried 3g sim but it seems no problem
Why my sim works without problem in Z1?
When i turn off data it works good but when i have a call its freezing again
Rickard
What if you try your phone with the 3G SIM and have your phone set to GSM only? If that works i suggest that you contact your operator to get a proper micro SIM.
Not sure why it works in your Z1 but if you have a worn or damaged SIM it may or may not work when you try it in different phones.
PeymanLasemi
With 3G it set to wcdma only
I though that my sim damaged i took new sim with new version but no difference
Joel007
i have the exact same problem...please can you figure out a solution,,,as if it is a software problem or a sim card problem or the device problem itself.
