10% of the battery is draining in 5 minutes
Sayed2
I have Xperia z1 I bought it from 8 months the problem is the first 10% is draining at 5 minutes and the battery isn't last for 4 hours
30 REPLIES 30
@Sayed2
did you purchased this phone new or used ? the phone was released 3 years ago, most likely you need a new battery, but
We'll need more info to better assist you
charge the phone 100% use it as you normally would then once the battery reaches 10%
settings > battery > take screenshots of:
1. the list
2. tap on the graph and take a screenshot
3. back > tap on the top 4 items on the list > take a screenshot of each
post them all here or upload the screenshots to box or dropbox or google drive or etc and post the link
@Sayed2
It seems normal, the screen was on for more than 3 hours plus WiFi was on. You could disable the Bravia Engine, keep in mind that some apps will drain your battery faster such as, facebook, whatsapp, games.
Sayed2
@uliwoody
Thanx for ur help but how I can make the battery life longer
@Sayed2
This is what I would do
First charge the phone 100% restart the phone > boot on  >>>> safe mode > use the phone on safe mode for couple of hours, and check if you experience the same battery drain, if you do, then repair the phone with
PC Companion (PCC)
Bridge (for Mac)
Xperia Companion (XC)
Software Repair Guide
Sayed2
I have Xperia z1 and it's battery drains very fast how can I fix this or I have to change battery?
https://drive.google.com/file/d/0ByKKZ7poEtCwLW1oWllORkpJRkk/view?usp=drivesdk
https://drive.google.com/file/d/0ByKKZ7poEtCwQnpWb2IyYW95ZUU/view?usp=drivesdk
I bought the phone since eight months
profile.country.PH.title
MarlonUk1
Can you click on the graph and postcthe screen shot? And also there seems other apps listed below the shown ones can you take a screenshot of those aswell?
Or you can just search and read similar problems using the search bar above.
Sayed2
This is the screen shot and I want know
If that the normal if for the battery?
