Xperia xa1 bad signal
Krs99
Hi
Upgraded from Sony aqua to xperia xa1 same sim card and the signal is not what I expected, doesn't even work most the time.
GPS on Google maps is all over the place and can't even use the sat nav
Disappointed in Sony any one else had signal issues
72 REPLIES 72
Krs99
Hi
it's nothing to do with the SIM card or the network. It's the phone I'm taking mine back for a refund
Here is instructions they sent me for repair
Dear Chris,
Thank you for contacting the Sony Xperia support centre.
We are sorry to hear of the issues that you are having with your Sony Xperia XA regarding the Mobile network signal.
We would suggest firstly that you try to use your SIM card in a different phone as the SIM card itself might be defected which will affect the network's signal.
If the SIM card works properly in a different handset, we would recommend that you reset your Mobile Network Settings by following these steps:
From your Home screen, tap the Application screen icon.
Find and tap Settings > Backup & reset > Network settings reset.
Find and tap RESET SETTINGS.
If this reset doesn't help sort the network's signal issue, we would suggest that you try to perform a repair of the software using Xperia Companion.
If the issue is related to a problem with your software this will be repaired and your handset will work as intended.
To do this, you will need to install Xperia Companion from the Sony Xperia website,
the application is available for both OSX and Windows based systems. You can download each from the following links:
Windows/PC:
http://support.sonymobile.com/global-en/tools/xperia-companion/
OSX/Mac -
http://support.sonymobile.com/global-en/tools/xperia-companion-mac/
Once installed to then perform a repair on your handset’s software, please follow the
steps below, making sure that at the start of the process the device is turned off and disconnected from the computer:
1. Open Xperia Companion
2. Click Software Repair
3. Some on screen steps will now appear for you to follow. Please do not connect the
handset until you are prompted to do so.
4. When you are asked to connect the handset (still with the phone powered off) please
press and hold the key stated on screen for 30 seconds before connecting the handset and keep it held down as you connect
5. The repair process should now begin.
Please ensure your handset is not connected to your system when performing the above
as you will be instructed to connect your handset once you have followed the above steps. Your handset must also remain powered off at all times.
Please note it may be the case that user data is lost during this upgrade. We therefore
recommend backing up any data to your SIM card, Memory Stick, or system before upgrading.
Please be aware that if an update to a later version of Android has become available
for your Sony Xperia handset the new version may be installed. If this is the case you may notice some differences in the functionality of your handset when updating. All information regarding these changes can be viewed on the following link. We would recommend
reading through the following before updating:
www.sonymobile.com/gb/software
If none of the suggested solutions above sort the issue with your Sony Xperia XA's signal problem, we would lastly recommend you to contact your Network provider for further assisstance.
We hope this helps you.
Avcool
In India signal reception have 3bars not 4bars, even on other phones same network same area shows maximum network i.e 4bars
Krs99
Hi
I get no service (no bars )
Avcool
India 🇮🇳 Signal reception has 3bar,while using same network on other mobile 📱 shows full 4 bars. Mean xa1 has poor signal reception need to b fixed may be through ota updates.
And where is android 7.1? Updates
profile.country.US.title
Qatrium
@Avcool
With all my due respect, you are getting it totally wrong. The bars do not indicate better reception if they are more. And the way you're holding your phone, the angle it's positioned at, and the surrounding will always affect the strength of the signal you receive.
Do you have any problems while making or receiving calls? Do you SMS's arrive later than expected?
O3
Wondering if the.Xperia L works in Canada, I can't seem to activate my cell phone with nell
Avcool
Yeah may be right, i do not have making or receiving call problems but, but why into other phone using same network in same area too considering same positioning of mobile get xa1 less bars then other
Qatrium
@Avcool
Signal bars are just a graphic on your screen. If you want to compare you can go to your Settings -> About phone -> Status -> SIM status -> compare numbers in "Signal strength" field. You need also to compare 2 identical phones nearly at the same place and position, because every phone may have its internal antenna in a different place inside the phone.
Avcool
Onto HSPA network getting - 92DBm, Lte network getting - 101DBm,
What about nougat 7.1?
Qatrium
@Avcool
Updates are released gradually and timing will differ between markets. Unless there is an official statement from Sony, the exact timing of update to your market will not be available here or anywhere else. Keep checking periodically on Xperia Companion.
