XA2 BT codec problem
Denö
When I trying pair XA2 with HU Pioneer MVH-X580BT, streaming work only with SBC codec. But my last XA1 work with this HU on AAC codec perfectly.
XA1 BT settingsXA1 BT settingsXA1 AAC supportXA1 AAC supportXA2 BT setting before pairingXA2 BT setting before pairingXA2 BT settings after pairingXA2 BT settings after pairing13218053.png
3 REPLIES 3
Jetzu
Try enabling developer options and selecting the desired Bluetooth codec in them
Denö
I tried, if you saw pictures.
Jetzu
I'm sorry, didn't notice since it's in Russian...
So, can't you change the SBC codec in developer options?
You can also check this, hope it helps:
https://www.reddit.com/r/GooglePixel/comments/78xq3m/psa_you_can_manually_change_your_bluetooth_code...
