Hello, Sony XA1's personal model.
I have a problem connecting to my pc when updating the firmware.
when updating the firmware it made an error at 80 percent. can not be turned on. only the red diode lights up when connected.
now to update no longer connect with the PC.
can not re-update over sony flasher - writes -
- Device connected with USB debugging off
- For 2011 devices line, be sure you are not in MTP mode
I tried through Xperia Companion - repair the software, but it will not connect - it will not connect. I do not know the advice.
do you have any advice ??
Thank you for your help
I had same issue, I tried any solutions forum xda, sony forum, but the only option is to send phone in warranty..
