XA ULTRA MAXIMUM TEMPERATURE
VEROES
Translation via Google translate:
Do you know until degrees celcius of temperature it is Celsius to warm this phone? and until degrees of temperature is considered abnormal or fails
Saben hasta que grados celcius de temperatura es normal que se caliente este telefono ? y hasta que grados de temperatura se considera como anormal o falla
profile.country.US.title
Qatrium
@VEROES
I used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum.
Your phone should be equipped with safety measures that will force it to turn off is its temperature exceeds the limit (I don't know how much Celsius). The camera application also will shut down automatically if the camera module gets too hot.
