Warranty issue
xperia_xa2
Warranty issue
Warranty of xperia xa2 Global or not?
Tags (1)
profile.country.US.title
Qatrium
@xperia_xa2
As @Jonathan2396 mentioned, Xperia warranty is usually region/market specific. But I suggest that you contact your Local support and discuss the issue with them, as they are well-informed about your region's warranty terms more than us on this global, user-based forum.
3 REPLIES 3
Jonathan2396
I think it's just from the country u buy the device
Qatrium
@xperia_xa2
Jonas
Hi @xperia_xa2, welcome to our forum!
As both @Jonathan2396 and @Quester pointed out, there is no Global warranty for our devices and the best option is to contact the Local support team where you bought the device and they will be able to provide you with a more detailed answer than we can here at our Global user based forum.
You can also if you like go to the link below, choose your country in the drop down list for Warranty and read some more about it there.
https://support.sonymobile.com/global-en/xperiaxa2/supportDocumentation/
I hope that helps! Slightly_smiling_Face
