Temperature too high or normal?
Rian42
Hi, I was interested in getting more information about my XA2 and installed a sys info app. The temperatures it showed for the pa_therm0 sensor seemed oddly high, between 85 and 105 degrees Celsius. I tested this with cpu-z as well to be sure. The results were roughly the same, contantly around 90 C. Now I wonder, is something wrong with my device? Are these readings normal? Does anybody get simmilar temp readings? Of course there is always the option that the apps show inaccurate values, still I'd rather be sure. Thanks for your help.
Jonathan2396
Dont know if its normal but have the pa_therm1 on 101c pa_therm2 on 103 pa_therm0 on 90 and flash_therm on 125c so think we are good (?)
5 REPLIES 5
Jonathan2396
davidhozic
My phone sometimes goes to 42°C (battery) when im just browsing
Rian42
Now that kind of calms me down. Seems like the temp readings are not accurate.
Thanks.
RE1281
Phone gets little hot but I think it's normal. All it matters is that it does not throttle cause of the heat. Which so far it has not in my XA2. I recall my old LG G4 and that phone would heat up like crazy and throttle.
AlexC2012
I have the same issue, i have pa_therm0= 90 degreesm, pa_therm1=100, pa_therm2=100 and flash_therm= 125 degrees constantly. Are these values ok ? I mean if i use the phone for 10 - 15 min for browsing and watching videos it starts to heat up around preatty noticeable. Is this a defect or a bug ?
Sony please answear !
