Having problems with Chrome, playstore, showbox and system us. All will open then become unresponsive and the message is to close or wait. Either causes the phone to eventually crash and take ages to restart. Only just started today. I've removed some apps to see if the memory is getting full. No change.
As far as I can tell so far. I've reinstalled showbox and it still happens. Was OK last night. All this started this morning. I removed some less used apps to see if it was a memory problem.
Do you have enough free internal storage? (take a screenshot if possible)
have you uninstalled and reinstalled the apps?
No (
Also Google play services is playing up.
Not solved. Button hit whilst scrolling.
Mostly it helps a lot deleting recently installed apps.
Swipe up or down from your home screen to find your apps.
Tap on the 3 dots in the upper right corner
Tap on Sort Apps
Sort on date installed
Delete the last few installed apps
Reboot
See what happens
Report back if it helped you.
