El altavoz de mi móvil no funciona correctamente. Cuando lo pongo yo escucho a la otra persona, sin embargo ellos no me oyen a mi.
Si no uso el altavoz el móvil funciona correctamente, también con auriculares
Es posible q sea una actualización de software? O tengo q enviarlo a servicio técnico?
Gracias
My mobile speaker does not work properly. When I put it on I listen to the other person, however they do not hear me.
If I do not use the speaker the phone works correctly, also with headphones
Is it possible that it is a software update? Or do I have to send it to technical service?
Thank you
gt
I also have the same issue, it only started yesterday (that's when I first noticed it), the mic works fine I think since I can record messages usin WhatsApp without issue.
When I call like normal handset to ear everything is fine but when using the speaker to listen the other party cannot hear a single thing, why is this?
Can't be a hardware error... V
I have the Xperia F3211 running the latest available Android 7 update.
