Sound
Ток
Sound
Sound
The speaker wheezes when playing music, and setting the multimedia signal. Was in the service a month ago, the problems did not reveal. Now it has begun again in utiuye and in music and SMS about the board. Restart helps partially.
Звук
Хрипит динамик при воспроизведении музыки, и настройке сигнала мультимедиа. Был в сервисе месяц назад проблемы не выявили. Сейчас началось поновой и в ютуье и в музыке и в смс о правлении. Перезагрузка помогает частично.
@Ток
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Does it happen with music stored on the internal storage? SD card? Streaming music? Streaming videos? which app are you using?
