Hello, please someone happens to the XA1 ultra when I use maps the location is not accurate and is disoriented? Some say it has no gyroscope, and I also had a failure from one moment to another while loading and playing clash royal turned off the phone as if it had spent the battery I tried to turn it on again and it turned out to be with battery at 0 when I had seen that was for 63% of charge before going off, because those failures if you have only one week of having bought it.
Hola por favor a alguien le pasa en el XA1 ultra cuando uso maps la ubicación no es precisa y es desorientada? Algunos dicen que no tiene giroscopio., y también tuve una falla de una momento a otro mientras cargaba y jugaba clash royal se apago el celular como si se hubiera gastado la batería lo intenté encender de nuevo y resultó estar con batería en 0 cuando había visto que estaba por el 63% de carga antes de apagarse, porque esas fallas si recién tiene una semana de haberlo comprado.
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
That's correct this Xperia doesn't have a gyroscope. As for the other issue, did you experienced that only once?
I thought it was just myth that this cell phone, I do not understand if they have forgotten or what will happen to have this big flaw, the experience with maps is very unpleasant to use GPS.
And if it's the only time that I've spent that battery, hopefully and never happen again, barely has a week of use and I'm thinking of getting rid of it, that gyroscope issue disappointed me enough.
Thank you very much for the reply.
Vaya pensé que solo era mito eso en este celular, no entiendo si se les habrá olvidado o que habrá pasado para que tenga esta gran falla, la experiencia con maps es muy desagradable al utilizar el GPS.
Y si es la única vez que me a pasado eso de la batería, ojalá y no vuelva a ocurrir., apenas tiene una semana de uso y ya pienso deshacerme de el, ese asunto del giroscopio me desilusionó bastante.
Muchas gracias por la respuesta.
