Hi good day!
It happens that when you lock the phone, the sim card is instantly disabled, as if there were none inside the phone.
But when you unlock the phone and use it normally, the sim card is activated again with all its normal functions!
Hola buen día!
Sucede que al bloquear el teléfono, la tarjeta sim se desactiva instantáneamente, como si no hubiera ninguna dentro del teléfono.
Pero al desbloquear el teléfono y utilizarlo normalmente, la tarjeta sim vuelve a activarse con todas sus funciones normales!
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Does the SIM card work with a different phone? have you tested different SIM cards?
Oh I'm sorry about the language.
Does the SIM card work with a different phone?: Yes.
Have you tested different SIM cards?: Yes.
But the problem it's still the same.
