Its in automatic brightness, but I found it strange that it flashes every moment, it's like the configuration is triggered. 3 days has passed since i bought, and when I remove the option of automatic brightness, the brightness is too strong... This has happened to you.
Btw it was update twice
I dont have this issue with the flashing brightness, but the manuelly brightness should be the same darkness as the automatic mode. I cant use automatic mode every where.. Ill hope they include this in Android 8.0
Guys, when you're using "automatic" brightness, it will often change brightness repeatedly, because it is continiously adapting the surounding lighting... For example, if the sun comes out from behind a cloud or you turn a light on, it will become brighter; but if the same sun goes behind a cloud or you turn a light off, it will get darker.
Perhaps this is what is happening here?
@Votan wrote:but the manuelly brightness should be the same darkness as the automatic mode. I cant use automatic mode every where.. Ill hope they include this in Android 8.0
Manual brightness should stay at the same level - the one you have specified - the whole time... In other words, it should not change brightness.
Is this not happening with your smartphone?
It not change brightness while manuell mode. But the darkest manuell option is like 3x darker then automatic mode if its night or dark in my room you know.
