Why does not otg work
Почему не работает otg
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
I'm not sure what seems to be the issue, the more info that you share the easier it'll be to help you, also check this
Hi @Hikmatshakirov, I am sorry to hear about this.
The XA series does have support for OTG host which means that you can connect USB devices to your Xperia device using a USB OTG (On-The-Go) cable. Do you receive any kind of error message when trying to use OTG?
Please do elaborate your question and post any replies in English and it will be easier for me and other users to assist you.
