Manual network selection does not work anymore
profile.country.AT.title
rem996
Member
Hello
After updating my Sony Xperia XA1 Dual (G3112) to Android 8, the manual network selection doesn't work anymore.
Well of course, the functionality is there and I can use it. However, I select a network manually and the smartphone looses the connectivity to that network for a minute or two, it kinda switches to automatic and chooses another availble network (roaming).
Anroid 7 which was installed before didn't have those problems. In the described scenario, the SIM card was simply disconnect until the manually configured network was back within reach.
Why was that changed? So where's the difference between automatic and manual network selection right now?
Please revert to the old behavior as this is what people expect when they select a network manually.
Thanks for your feedback and support
Remeus
10 REPLIES 10
rem996
Member
Hello
I was able to download the 7.0 Version using Flashtool via xpericheck.com and flash it afterwards.
Only annoying thing is that you're not able to permanently turn off the update notifications; but I can handle this.
Regards
