Loudspeaker cannot produce max volume
cathelim
Hi! Need help on my XA1 Plus. The loudspeaker does not produce max volume. It is also sometimes muffled.
3 REPLIES 3
Martin1
Enthusiast
Hi @C933, I am sorry to hear about this.
First of all i would suggest that you remove any protective case or cover to verify that it's not interfering with the loudspeaker. Secondly, have you used the Tests feature in the Support app to carry out a quick test to check that the loudspeaker is working properly? In order to do this, Find and tap Settings > Support > Tests > Media.
You can also use safe mode to check if any downloaded applications are causing the this. If the performance of the loudspeaker improves in safe mode, it is likely that one or more of your post-purchase downloaded applications are affecting the device negatively. For more information on safe mode and how to use it, click here
Try these measures and let me know how it goes!
cathelim
Hi! Loudspeaker still does not produce good quality sound. I guess it's the hardward.  Will just send it to an authorized repair center. Thanks for the help though! Slightly_smiling_Face
Martin1
Enthusiast
No worries, @C933!
Let me know if there is anything else I can help you with! Slightly_smiling_Face
