Hi. A few days ago I made the purchase of a Sony Xperia XA1 Plus. And the charger that I brought in the box that is 1.5 milli amperes does not raise fast charge. I wanted to ask them what shipper could buy in Argentina if it is. As I read it has to be compatible with Pump Express 2.0 technology from Mediatek. Could you tell me if there is a charger that you can buy in Argentina or if there is one that the amperage should have that you use to recognize the fast charge. Can i use a charger with an accurate amp level? That output amperage should have the charger for the device (Xperia XA1 Plus) to recognize the fast charge.
